Sulfur in water
Slight odor cold side, stronger on hot side.Waiting for water test results.0
When testing for sulphur, the test needs to be done quickly after sample is taken."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
After a long delay the well pump company finally came. I have excessive iron in the well.I can change water softener pellets to those that remove iron and change anode rod .Or have a New well installed.New well 12,000 bucks. I’ll try pellets and anode rod first.0
I mean,MIKE6 said:After a long delay the well pump company finally came. I have excessive iron in the well.I can change water softener pellets to those that remove iron and change anode rod .Or have a New well installed.New well 12,000 bucks. I’ll try pellets and anode rod first.
Wouldn't the new well get the same water as the old one?Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Yup. Unless your local geology is really strange... get the proper water treatment.ChrisJ said:
Wouldn't the new well get the same water as the old one?Br. Jamie, osb
Hi, You might want to look into shocking the well: https://www.bing.com/search?q=shocking+well&form=QBLH&sp=-1&pq=shocking+w&sc=8-10&qs=n&sk=&cvid=1BE8B63D786E4904808C5BE229483474
Yours, Larry0 -
No harm to trying it. Though if the water is inherently high in iron or suphur, the problem will come back...Larry Weingarten said:Hi, You might want to look into shocking the well: https://www.bing.com/search?q=shocking+well&form=QBLH&sp=-1&pq=shocking+w&sc=8-10&qs=n&sk=&cvid=1BE8B63D786E4904808C5BE229483474
Yours, LarryBr. Jamie, osb
I have well water Northern NJ. Similar problem. Smelly water. So I socked the well first. Then install a new softener with a big iron filter. Within a week the problem solved, Bought the water treatment appliances from www.apluswater.comThank you,
Hiren Patel0 -
We have a few PPM of sulfur in our water. A water softener reduced the smell, but did not eliminate it. A local water treatment guy installed a system that uses air and birm media to oxidize the sulfur. Cost was about the same as a water softener, and totally eliminated the smell from our water.MIKE6 said:Was told by a pump co.my sulfur odor in the well water can be repaired with an anode change.But what I see it reduces corrosion.Also can anyone recommend a filter system to get rid of sulfur in water?
here is what I use at my house for that condition. When it backwashes, the water comes out blood red.
https://www.hellenbrand.com/product/commercial/filtration-systems/iron-curtainBob "hot rod" Rohr
If you chlorinate the well you should bypass the water softner or you can destroy the resin in the softner i would run water outside it may it may oxidize the iron and make a mess depending on the type of iron also high amounts of chorline is not good on pex for extended time also iron bacteria will give you a suphur smell sometimes drilling a new well is not a good solution0
It all depends on how much sulfur. With low levels, the above solutions will work. If the levels are high, you need to inject chlorine or hydrogen peroxide and then filter with RO.
As with any troubleshooting, first, run tests to evaluate the problem then work on the solution."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
"But what I see it reduces corrosion."
The anode material also has a chemical reaction with the hydrogen sulfide.
Many years ago we were on well water and had a sulfur smell problem. It's in all the water obviously but only really noticed it on hot, which made bathing unpleasant. After spending a fortune on water treatment devices, chlorinator/dechlorinator/carbon filter, chemicals, etc., someone finally mentioned the anode material in the water heater, maybe the heating element, too. Changed it. Problem gone. Trashed all the other expensive equipment.
Change the anode first.0 -
Maybe wasn't clear -don't change the anode for the same type, you swap materials.0
Hi, I've found that if the sulfur odor is coming from the water heater, than replacing the sacrificial anode with a powered anode nearly always fixes the problem. This somehow prevents hydrogen gas from being generated inside of the tank and the sulfate reducing bacteria, that causes the odor don't appreciate it.
Yours, Larry1
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 995 Plumbing
- 391 Solar
- 55 Water Quality
