Train XL 80 - worked fine until yesterday
The Nest may or may not be telling the truth, but it would be well to check. Do you have power (24 VAC) on the wires coming to it from the boiler? No? OK. Go back to the boiler. Do you have power on those wires at the boiler? No? OK. Do you have 120 VAC actually coming to the boiler itself? Your grounds and neutral are good?
No power at the boiler? Check for emergency shutoff switches that got shut off. There may be more than one, and they sometimes hide in odd spots.Br. Jamie, osb
Is there a fuse on the control board inside the furnace? Look at where the thermostat wires are connected, sometimes that printed circuit board (PCB) is equipped with a 3 amp automotive-style fuse.
Next Q. How long has the Nest Learning Thermostat been in use?
Q. Do you know if the Nest Learning thermostat is wired with a common wire? There will be a wire connected to the C on the Nest Learning thermostat. The programming on the nest wiring screen will indicate if the Common Wire (C) is connected or you can look at the actual wires by pulling the Neat Learning Thermostat off the wall and look at the sub base.
Isn't it nice how others will tell you to throw hundreds of dollars away and truly believe they are helping you?pecmsg said:Throw the NEST in the garbage. There garbage anyway.
I doubt that the Nest has anything to do with this one. The OPs comment that the boiler seemed to have no power is the fundamental problem here. So step one is find out whether power is even reaching the boiler in the first place, and if not, why not.Br. Jamie, osb
Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England3 -
> @EdTheHeaterMan said:
> (Quote)
N E S T bought the rights to the replacement for the electronic T87F after Mercury was banned. Honeywell realized power stealing didn’t work on several systems.
Look it up yourself. N E S T has more complaints then any other stat on The market.
OP
Change the N E S T and watch your troubles go away.1 -
Could a switch have been turned off by mistake?
The lower section door has a little spy hole. The control board has status lights. Green, Amber, and Red. Red being not good. Check the manual to the corresponding blinks, if any.
As long as you don't see any Red diagnostic lights, turn the switch or circuit breaker off for 5 minutes. Then on.0 -
One can learn about the product or complain about the product. I have chosen to learn about the product.
I believe there were Dead Men who said that these copper pipes will never catch on. And they died believing that copper pipes for boilers and plumbing will never catch on.
Now we are past copper and on to PEX. I wonder what the dead men would have said about that?
Just saying
" I think thermostats with numbers on them are junk" at any price. What does a number mean anyway? 60° F at 90% RH feels warmer than 70°F at 20% RH! So how do we teach our customers that the numbers are relative to the humidity? Or should one just make then pay for a service call to tell them that there is nothing wrong and let them call again and pay again the next time the numbers on the thermostat don't match how they feel
"Warmer <<< >>>Cooler"
...would solve many nuisance calls or we can just sell them a new thermostat for a couple of hundred and say the one they have is Junk.
@pecmsg you have convinced me. I will throw my Nest Thermostat and cameras and smoke detectors and other nest products in the garbage. You have a persuasive way of presenting your self. I'm happy you were able to convert me
@Jamie Hall I agree with you. except the Trane XL 80 is an 80% furnace... so there is probably a fuse on the circuit board.
Still wondering how old the Nest thermostat is. 8 years (same as furnace) or more recent?Edward Young Retired
A very knowledgable and experienced person posting here said, "Change the N E S T and watch your troubles go away."
@rob1969 after you spend big bucks on a new wifi thermostat, if you still have the problem then, check the fuse.
This is a normal procedure for most technicians in our industry. Go the large $ repair and if that does not work then look for something cheaper. That way we can make the expensive fix look like we were right, to begin with.
I'm not a fan of parts changers. I like to find the problem before I fix it.
I don't like the Nest thermostat either. I definitely get more service calls regarding them than all other thermostats combined...
That being said, I would definitely make sure the fuse isn't blown on the furnace control board. Also make sure you have the common C wire connected to the thermostat and control board on the furnace.1 -
Nests arent bad anymore. When they first came out they were a pain. Check for a burnt terminal.0
Nests are good at hijacking threads. And in this instance, I think that @rob1969 certainly has enough places to look -- without worrying about the thermostat.
To clarify though, on my objection to Nests: first, my objection is not to the Nest, but to an entire class of thermostats which think they know better than the occupant how the system should be run. They sometimes do; particularly with fast responding heating systems such as forced air, which is what they were designed for and meant to be used with. Sometimes they don't, and have to be fiddled with to give good results. Second, I object to any device in my home which broadcasts what I am doing, when, and with whom to the world wide web.Br. Jamie, osb
Thanks to all of the positive comments and insight. my comment about the Nest is the system does not appear to have power. Hence the fuse potential issue. I will open up the unit today.
Is this why we have houses that were built in the 50's that have galvanized pipe even though it couldn't have been less expensive than copper even then with all the additional labor and they should have known by then that they would rust and fail but copper had been available for about 20 years at that point?EdTheHeaterMan said:One can learn about the product or complain about the product. I have chosen to learn about the product.
I believe there were Dead Men who said that these copper pipes will never catch on. And they died believing that copper pipes for boilers and plumbing will never catch on.-1 -
There will be a plug type 5 amp fuse on the control board in the lower blower section.
That door also (should) has a door switch.
Once you check/replace the fuse, you can check the status lights with the door off by depressing the switch. Just make sure all other switches and the breaker are on.1 -
@mattmia2 You might be correct with your observation. I try to put myself in the mind of the original installer whenever I can. Maybe the plumber had a ton of galvanized pipe left in his warehouse when he got the job to rough plumb the home... so the new copper would cost more than using up dead stock.
We are putting in a lot of condensing furnaces now-a-days. so what do I do with all the b-Vent in my tin shed? Repair the vent pipe for Trane XL80 furnaces maybe? But this is off-topic.
I would certainly like to hear the resolution of PO's problem
If it is a fuse... after you replace it, it may blow again. If so, you will need to locate the source of the overcurrent. I had a problem with the landscaper using a trimmer near the outdoor AC unit. The low voltage wire insulation was worn off and from time to time the wire would short circuit. The heater worked fine all winter. As soon as the AC was activated in the spring... pop goes the fuse. No heat and no AC.
2
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
