Mixing valve just before fixture
What about faucets with built in mixing valves?
I run our HW near 140F and my wife hates it and I don't want to lower it. The kitchen sink, dishwasher etc like it among other reasons.
While we're talking bathroom faucets, what's a nice flow rate these days? 2.2 seemed to be the old one, but how bad are the 1.2's and 1.5s?
A thermostatic mixing valve is installed on the HW Tank on the HW outlet. It mixes the outbound temp to 120 degrees to the fixtures. This is called for in the code. 140 is scalding and can cause serious burns. It's fine to keep the tank at 140...it minimizes legionella bacteria.0
I have a recirculating loop which I will not be keeping at 120.Paul Pollets said:A thermostatic mixing valve is installed on the HW Tank on the HW outlet. It mixes the outbound temp to 120 degrees to the fixtures. This is called for in the code. 140 is scalding and can cause serious burns. It's fine to keep the tank at 140...it minimizes legionella bacteria.
So, I need another option.
Why does the recirc loop matter? Usually it's the same temp as the outlet of the tank. I presume it's pushing towards the tank and has a check valve on the pump's discharge side?
Because I don't want to risk Legionella in the loop.Paul Pollets said:Why does the recirc loop matter? Usually it's the same temp as the outlet of the tank. I presume it's pushing towards the tank and has a check valve on the pump's discharge side?
I can actually keep the kitchen loop it's own temperature as the bathrooms are isolated from it. So, I could put a mixing valve on just that loop, but Legionella does concern me even if the tank is in theory free of it. Could I be concerned over nothing? Perhaps, I don't know.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Ah ha.ratio said:I know I've seen point of user mixing valves. Might be called anti-scald valves.
I'm getting pretty far out of my area, but I think they're required by code, at least in certain circumstances.
"point of use" is what I needed in my search.
https://www.supplyhouse.com/Zurn-38-ZW3870XLT-4P-3-8-Aqua-Gard-Thermostatic-4-Port-Mixing-Valve-Lead-Free-Compression
Caleffi SinkMixer 3/8 compression connectionsBob "hot rod" Rohr
Living the hydronic dream1 -
Some years ago I was working in a private home/day care.
Most of these are inspected by the State for safety issues.
On the sinks there was a different aerator installed.
It was temp limiting and would close up if that temp was reached. It would auto open again after cooling off a little.
Never saw any again nor a source.
Disadvantage was you had to mix H&C yourself to keep the water on......not a bad learning process for toddlers.
With pre mix under the sink or elsewhere, you just turn on the HW, never mix perhaps. Not necessarily good as you go to a non tempered HW supply expecting it to be safe and get surprised.2 -
- 120 Geothermal
