anyone know Gree mini splits?
I'm trying to figure out the difference between their MULTI21 and MULTI+. their documentation does not seem to show much difference, other than their smallest unit can do a single indoor with the +, and the + gives BTU output values at -5° and the regular gives it at -4, but that's all the difference I can find. I tried to contact them through their website, but haven't heard back.
    HVACNUT Member Posts: 7,308
    edited April 2020
    Never heard of them. Are they a subsidiary of a major brand, like a cheap builders model type of thing?
    IMO there's only three worthwhile Mini split manufacturers. Mitsubishi, Fujitsu, and Daikin. Not necessarily in that order.
    hot_rod Member Posts: 27,082
    They claim to be the worlds largest residential A/C manufacturer. They always have interesting stuff at at the ahr show. I suspect they private label many units.
    I don’t know the difference in those units?
    HVACNUT
  • weil_fail
    weil_fail Member Posts: 84
    yeah, I hadn't heard of them until recently. they're Chinese, but they're a major player in the worldwide market. from the installers I've heard from, they're kind of middle-of-the-road in quality. no Mitsubishi, but not bad. in fact, I would bet many of the smaller brands are probably relabeled Gree units.
  • BillyO
    BillyO Member Posts: 277
    100 percent Chinese , contractor uses them on jobs I do plumbing. nothing but problems. just saying
  • Big Ed_4
    Big Ed_4 Member Posts: 3,412
    edited April 2020
    Sounds like disposable equipment .With bad tech support .. They can not supply you with basic information ..Good Luck
    pecmsgSuperTech
  • Swtbbyjms
    Swtbbyjms Member Posts: 1
    edited December 2021
    I bought a Gree for my new three bedroom house. Had a contractor install it.
    Nothing but problems. I wish I had spent more for one that local contractors are familiar with.
    I’ve never been able to contact a Gree representative or even find a working number for Gree.
    When I try to find a local company that works on Gree, it says there are none in my area.
    Two of my controllers have stopped working.
    I plan to totally replace my entire system soon with better known unit such as Fujitsu.
    EBEBRATT-Ed Member Posts: 19,908
    @Swtbbyjms
    Mitsubishi is usually considered the best. Fujitsu seems to be good as well
    pecmsg
