Mr Steam Control Panel
RayWohlfarth
Member Posts: 1,782
My brother called from North Carolina and is looking to see if there are replacement controls for a Mr. Steam bathtub. He called the manufacturer and they said they no longer support the product and suggested he spend $5,000 for a new one. Is this a lost cause?
Thanks
Ray
Thanks
Ray
Ray Wohlfarth
Boiler Lessons
Boiler Lessons
Do the buttons still work?
If not, it might be something other than the control, i.e. power in, fuse, low water, etc.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
@STEVEusaPA I thought the same thing but lots of liability with that tho
@Alan (California Radiant) Forbes Not sure I will ask He says it burns the Cr** out of you
@hot_rod Thanks I will let him knowRay Wohlfarth
Boiler Lessons0 -
There must be a temperature sensor on the control.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
I think Ebay is the best option. There are likely several models using the same controller, maybe even other brands I would be curious what the schematic for the steam gen looks like. I've tried reverse engineering proprietary controls like that with little success. Have him take a picture of the nameplate, schematic and control board on the steamer."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Hi @RayWohlfarth , This might be a good place to look: https://www.steamsaunabath.com/catalog/mrsteam-smarttwo-smarttwo-control-mrsteam-p-1759.html
Yours, Larry0 -
hi, did you ever figure something out- we are in the same boat after a shower Reno and no way to find similar controller
Ray, I got one in polished chrome. New, unused, in original box with all parts (steam head, wall flange, cable etc.). Part# MS1-PC I was keeping it to pass on to my heirs. Mine is for a steam shower. I'll post a pic tomorrow.
@AGhai do you just need a sticker for the front and not the whole control? I have an extra sticker, black.
@AGhai Have you tried calling Mr. Steam technical support? (800)727-8326
I have the same issue. Looking for a replacement sticker. Any leads?
- 87K THE MAIN WALL
- 112 Chimneys & Flues
- 106 Geothermal
- 979 Plumbing
- 387 Solar
