Mr Steam Control Panel
Ray
Boiler Lessons
Do the buttons still work?
If not, it might be something other than the control, i.e. power in, fuse, low water, etc.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
@STEVEusaPA I thought the same thing but lots of liability with that tho
@Alan (California Radiant) Forbes Not sure I will ask He says it burns the Cr** out of you
@hot_rod Thanks I will let him knowRay Wohlfarth
Boiler Lessons0 -
There must be a temperature sensor on the control.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
I think Ebay is the best option. There are likely several models using the same controller, maybe even other brands I would be curious what the schematic for the steam gen looks like. I've tried reverse engineering proprietary controls like that with little success. Have him take a picture of the nameplate, schematic and control board on the steamer."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Hi @RayWohlfarth , This might be a good place to look: https://www.steamsaunabath.com/catalog/mrsteam-smarttwo-smarttwo-control-mrsteam-p-1759.html
Yours, Larry0 -
hi, did you ever figure something out- we are in the same boat after a shower Reno and no way to find similar controller
Ray, I got one in polished chrome. New, unused, in original box with all parts (steam head, wall flange, cable etc.). Part# MS1-PC I was keeping it to pass on to my heirs. Mine is for a steam shower. I'll post a pic tomorrow.
@AGhai do you just need a sticker for the front and not the whole control? I have an extra sticker, black.
@AGhai Have you tried calling Mr. Steam technical support? (800)727-8326
I have the same issue. Looking for a replacement sticker. Any leads?
Hi HomerjSmith - any chance you still have a sticker for the steam shower on/off switch?
Yes, I do have a black Mr . Steam wall switch box label.. I'll look it up and post a pic.
