Heat Loss
superdave
Member Posts: 155
Hi All,
Does any one have good heat loss program they use. I am getting pig swings from supply house and they 3 of them have same prints. I know we like being safe on heat an add some %% to cover us but something seam off.
Thanks
David
Thanks
David
Here you go: https://www.slantfin.com/slantfin-heat-loss-calculator/
the click for your laptop is at the bottom of the page. Or download the app.Br. Jamie, osb
Thank you for your time. Just seem light 3,200' house with 22' 18' ceiling in three room and came out about 11-15 BTUs per square foot from supply house and I told him about high ceilings.0
You can run the SlantFin program for yourself. Never hurts. It's pretty straightforward.Br. Jamie, osb
I suggest you take 8th Grade Earth Science.
Home schooling now dealing with convection, conduction, radiation, dynamic equilibrium, etc. Holy ****!!!
I dont remember doing that stuff.
The Slant/Fin app is a good one.0 -
My kids are in 7th and 3rd I am so lost the math makes no sense to me what happen to 25x35=875 one set over anther now you need to box the number round up and down math !!!!0
When I first open my company in late 90s as a quick rule about 30-35 BTUs per foot just to get a starting point. As house got better insulation I have gone down 25-30 BTUs per foot. Now some of the new houses its all glass walls that I could drive a truck through.0
Unfortunately, the SF application is for baseboard or radiator sizing, not radiant floor heating.0
Then you definitely need to download the free Slant/Fin app.
0+0=0
Or Bluto's GPA. 0.00 -
Not true, @Paul Pollets . The Slant/Fin application has two parts: one gives you the heat loss of the structure. The other, conveniently if you happen to be using baseboard, gives you the sizing for that.Paul Pollets said:Unfortunately, the SF application is for baseboard or radiator sizing, not radiant floor heating.
Nobody -- including Slant/Fin -- says you have to use the second part. The structure heat loss will be the same, regardless of what means you plan to heat it with. I have used the app. quite successfully for everything from passive solar to forced hot air to hot water to steam to radiant to wood stoves.Br. Jamie, osb
The app has fluff built into, even if you're aggressive with the ACH. Whatever it comes up with I would consider an upper limit but it's far better than a guess on sizingYou can have it good, fast or cheap. Pick two0
Thanks for your help. I had the older Slant Fin heat loss on old Vist. Computer. and just had been using suppliers to do it for me but the guys that did it in past are not available and the 2 guys came up with low numbers. I have down loaded new one but can't print out for some reason.0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 983 Plumbing
- 389 Solar
