Dreams
Member Posts: 4,663
I had a disturbing dream last night that on a flight home from Frankfurt, Germany, I realized that I left my suitcase in my hotel room. And then later, I woke myself and my wife up, flailing my arms and legs. The dream was that we were driving down a steep, winding hill and my legs weren't long enough to reach the brakes and we kept going faster and faster. Very quickly, the turns became difficult as we speeded up. Disturbing dreams in the middle of a pandemic.
As I lay there with my heart thumping, I started thinking about the way my heart works as a pump. There are two distinct pathways: from the heart to the lungs and back (pulmonary veins and arteries) and from the heart to and from all the other organs and parts of my body. Just like a primary-secondary hydronic system, only with one pump. The lungs are the boiler, absorbing oxygen from the air that we breathe and the organs and extremities are the distribution system, with the pump sending oxygen to every cell in your body. Human physiology is pretty impressive, no?
In addition to pumping, your heart acts as a low-loss header with a reservoir and four outlets.
I've always considered the primary pump for hydronic heating to be an expensive necessity as it only needs to overcome the pressure drop in the boiler and provide enough flow to pick up the heat from the HX; not that hard on most boilers. And piping a primary-secondary system takes time, even with pre-piped kits. And then I thought about one pump with four outlets that could do both primary and secondary duties; perhaps an ECM pump that could dial in the required flows for the boiler and the system. It could be offered stand-alone or directly connected to a low-loss header. It could even be incorporated inside the boiler with only system piping connections.
Any thoughts? I'm sure I'm not the first person to think of this.
Might work, @Alan (California Radiant) Forbes , for a heating system -- but you forget that although the heart has four chambers and two circuits, there is no mixing between the pulmonary side and the body side. Or there better not be! The circulation is from the body's main veins into the right atrium and then into the right ventricle -- a two stage pump, no less! -- then out to the lungs. Then return from the lungs into the left atrium and then the left ventricle (another two stage pump!) and out through the aorta and back to the body. Ingenious... amphibians and reptiles are three chambered, and there there is mixing.Br. Jamie, osb
The heart muscle is one of the longest lasting, low ,maintenance circulators available. Some run in excess of 100 years with little to no maintenance.Bob "hot rod" Rohr
Studies have concluded that all mammals get about a billion heartbeats per lifetime. They can use them at a rate of a thousand per minute, like the shrew, or space them out into slow, ponderous beats, over many years, as is the case for the Grey whale.0
I hope it's more than that. At 60 bpm that's only 32 yearsYou can have it good, fast or cheap. Pick two0 -
You heard it here, fellas!8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
- 121 Chimneys & Flues
- 15.8K Strictly Steam
