How can I increase the pH of the water in a radiant floor heating system?
storer
Member Posts: 2
The boiler manufacturer (Cleanburn) recommends that the system fluid have a pH between 8.5 and 9.5. The water out of the tap has a pH of 7.0, what is the best way to increase the pH? This is a 5000 sq. ft. radiant floor heating system with about 200 gallons of water in the system (due to a large buffer tank).
@Erin Holohan Haskell
We seem to have parallel posts. Any chance they could be combined?"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
We've combined these posts. Thanks!Zman said:@Erin Holohan Haskell
We seem to have parallel posts. Any chance they could be combined?President
HeatingHelp.com0 -
What about hardness and TDS? If you just want a Ph boost they have products for that. i prefer a treatment that would buffer Ph, scavenge O2, provide some film protection. But you want to put conditioners in a cleaned system with good water quality.
https://www.rhomarwater.com/Products.htmlBob "hot rod" Rohr
The MSDS active ingredient in PH increasers is KOH (Potasium Hydroxide).0
Thanks for the input, I have been using Sentinel products and they have a corrosion inhibitor, but had nothing to say about increasing pH. I'll look into the Rhomar and Fernox products and let you all know if I have further questions. Thanks again!0
