How can I increase the pH of the water in a radiant floor heating system?
storer
storer Member Posts: 2
The boiler manufacturer (Cleanburn) recommends that the system fluid have a pH between 8.5 and 9.5. The water out of the tap has a pH of 7.0, what is the best way to increase the pH? This is a 5000 sq. ft. radiant floor heating system with about 200 gallons of water in the system (due to a large buffer tank).
  • GroundUp
    GroundUp Member Posts: 2,506
    I like Rhomar 922 personally, it can control pH as well as adds corrosion inhibitor
    kcopp
  • Zman
    Zman Member Posts: 7,611
    All the big treatment companies will have a product for this purpose. Fernox, Rhomar....
    @hot_rod likely has a recommendation.
    Albert Einstein
  • Zman
    @Erin Holohan Haskell
    We seem to have parallel posts. Any chance they could be combined?
    Albert Einstein
  • Erin Holohan Haskell
    Erin Holohan Haskell Member, Moderator, Administrator Posts: 2,363
    We've combined these posts. Thanks!
    President
    HeatingHelp.com
    hot_rod Member Posts: 27,322
    What about hardness and TDS? If you just want a Ph boost they have products for that. i prefer a treatment that would buffer Ph, scavenge O2, provide some film protection. But you want to put conditioners in a cleaned system with good water quality.
    https://www.rhomarwater.com/Products.html
  • HomerJSmith
    HomerJSmith Member Posts: 2,774
    The MSDS active ingredient in PH increasers is KOH (Potasium Hydroxide).
  • storer
    Thanks for the input, I have been using Sentinel products and they have a corrosion inhibitor, but had nothing to say about increasing pH. I'll look into the Rhomar and Fernox products and let you all know if I have further questions. Thanks again!
