For you electricians and wannabes
hot_rod
hot_rod Posts: 28,500
I had to order one of these. They have tees, sweatshirts, aprons available.
We need a hydronics version!
rick in AlaskaSolid_Fuel_Manicy78Grallert
  • JUGHNE
    JUGHNE Posts: 11,643
    And not all people realize that all those electrical terms refer to "Dead Men".
    Solid_Fuel_ManIntplm.
  • Solid_Fuel_Man
    Solid_Fuel_Man Posts: 2,644
    Dead Men paved the way for all the trades. Mr. Volta, Mr.Ampère, and Mr. Ohm. The Italians, French, and Germans.
    mattmia2 Posts: 18,198
    or that there are thermodynamic equivalents of those
    Solid_Fuel_Man
    That's what we need to come up with!
  • Ok. I’ll bite. Volt is pressure. Ohm is friction and amp is flow... or something like that :p
    Yours, Larry
  • mikeg2015
    mikeg2015 Posts: 1,194
    Yup. Pressure, flow, Head loss. Then you have temperature drop/rise.
    Would be better done with minions i thumbnails.
  • Bob Harper
    Bob Harper Posts: 1,188
    High pressure to low pressure; hot to cold, path of least resistance, vena contracta, WRT, etc.
  • ChrisJ
    ChrisJ Posts: 17,718
    edited March 2020
    Except that electrons flows - to +.
    Also current will more often than not take every path, not just the lowest resistance.
    Solid_Fuel_Man
  • Intplm.
    Intplm. Posts: 3,156
    I for one miss my old "Carpe Hydronicom" tee shirt.
    Any one else remember those shirts.
  • We've got some shirts here and may get working on some new ones: https://teespring.com/stores/heatinghelpcom-store
    Thanks for the inspiration!
    President
    HeatingHelp.com
    Solid_Fuel_Man
    Fluids and heat will take every path proportionally exactly the same way electricity will...
    In fact usually they teach all engineers either basic circuits or thermodynamics at most universities to teach them the theory of how to solve that type of problem in all sorts of applications.
  • JUGHNE
    edited March 2020
    My kids got this for me a few years ago.
    Maybe good for some ideas for hydronics?
    Yes, I really am an electrician.
    That is a plugging/jogging diagram for reversing 3 phase motors.
  • HomerJSmith
    HomerJSmith Posts: 2,833
    "Electricity is really just organized lightning."-- George Carlin
  • Hap_Hazzard
    Hap_Hazzard Posts: 2,929
    Not exactly. Electrons tend to flow at the surface of a piece of wire instead of going through the center.
  • ChrisJ
    > @Hap_Hazzard said:
    > (Quote)
    That's pretty much AC only.
    https://en.m.wikipedia.org/wiki/Skin_effect
    mattmia2HomerJSmith
    Also, more the abstract idea of a schematic more than the specific physics of it in the components. Just the idea that electricity follows the path of least resistance is wrong. It follows all paths in proportion.
  • ChrisJ
    Can you imagine if it was true? Only the building with the highest load "lowest resistance" would get power from the grid. All others would get nothing.
