Aprilaire humidifier Controls
pmarinello489
Member Posts: 23
I have a Honeywell T10 thermostat, it can control a humidifier. It uses 2 wire U terminal. I would like to install the Aprilaire 865 unit as my house has no ductwork. I notice install instructions thermostat uses 4 wires. What would be required to get this working off of the Honeywell Thermostat, I'm assuming some sort of simple relay. I attached the instruction wiring page.
You want to land the U terminals on the "HUMIDISTAT" terminals on the humidifier. Do not install any jumpers at the thermostat, you do not need the 24 VAC coming from the humidifier ("Tap Connectors" on the schematic) either.
Double check the programming of the U relay, I'm not certain but I suspect it needs to be set to normally open, close to humidify.
So your saying I would only need the two "H" wires straight from the humidistat to my U terminals and don't need that 24VAC transformer connected to anything? Simple...0
Right. The H wires are the command to the humidifier. The other two wires from the humidifier are power for the humidistat, but the Honeywell is already powered (I assume!), so we don't need them. The U terminals are a dry contact (they don't provide power) that can be configured for humidifier control, just like we want.0
yes. yes I see thank you so much. Very simple.0
Your welcome.
Post back after a while & let us know how it's working. Or if, I suppose.
Make sure the U Slider Tab is down on the T10.0
I am just gathering my information for now, Winter is almost over so my humidity levels are going to rise but when I do start my basement work in a few months I know what I am doing!0
You don't need a "Humidifier" in the summer months just the winter.pmarinello489 said:I am just gathering my information for now, Winter is almost over so my humidity levels are going to rise but when I do start my basement work in a few months I know what I am doing!
Thank you... haha0
- 117 Geothermal
