United States Radiator Corporation in Dunkirk, NY
Kybeans403
Member Posts: 56
Rivited construction probably dates to the 20s or before. Welding came on steam around 1915 but it took some time before it was commonly used.
Did it have a date stamped on it??0 -
IS that an atmospheric expansion tank in and attic for a gravity hot water system?0
That would be my guess also. Sometimes they were installed on the highest floor up high on the wall to avoid freezing in the attic.0
was the bottom half drawn in a press then the top just riveted on?0
I’m going to guess it’s crimped and then possibly lead soldered in some manner. Top is assembled later after the various taps are added, which appear to be threaded bulk-head type fittings, so there’t a nut on the back side and a gasket.mattmia2 said:was the bottom half drawn in a press then the top just riveted on?
Top gets riveted and probably has a gasket of some sort. Looks like it gets galvanized afterwards.
Just a WAG on this.0 -
Hi, Looking closely at the bottom edge, I see it's uneven, like it was welded. So my guess is that the bottom head was drawn and pressed into place, then welded.
Yours, Larry0 -
If it is seamed I just wonder why they would do the bottom one way and the top another.0
Rivets on bottom! After I went back the next day, I actually brought a little hand pump and small bucket of water and tested the relief/overflow channel.......it was a copper channel, which ran under the cedar shakes, roughly 10 feet to gutters....and it didn't leak a single drop!
I cannot find a date, BUT my customer who lives there is in here late 70's and her parents originally owned the house so early 1900's is accurate.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
