Steam boiler vs hot water...boiler?
ethicalpaul Member Posts: 7,762
It makes perfect sense to me that my steam boiler is called a "boiler"
But why are the things that make the hot water for radiant systems called "boilers"? They don't boil anything!
I can't be the first to wonder this.
  • RayWohlfarth
    RayWohlfarth Member Posts: 1,790
    I think its because Water Heater was already taken. I often thought a hydronic boiler should be called a simmerer
    Ray Wohlfarth
    Boiler Lessons
    HVACNUT Member Posts: 6,871
    Oh boy, this is gonna be a long weekend.
    It's a pressure cookerer... er.
    ethicalpaulCanucker
    I thought of a possible reason. Steam heat predates hot water heat, right? And even today some boilers are made for both, so I imagine in the first days of hot water heating, all the hot water was created by converted steam boilers.
    So it just made sense to keep calling them boilers, since in many cases, that's exactly what they already were...just colder versions of them! Maybe?
  • bburd
    bburd Member Posts: 1,173
    No doubt they were exactly the same appliance in the early days of hot water heating.
    Interestingly, although any low pressure steam boiler made today can easily be converted to produce hot water, many “boilers” designed for hot water cannot be converted to make steam.
    Bburd
  • mikeg2015
    mikeg2015 Member Posts: 1,194
    I agree that it’s because in the early days it was always the same appliance used for either one with dual ratings, just as many have now. the basic block has dual ratings and you simply install different trim and piping.
    I believe Steam did come first since it was used for motive power primarily, then later used for heating inside homes once practical.
    Water was harder ot use as there were no pumps and you had to rely on gravity systems with oversized pipe that offered little advantage over steam other than more mass.
    Worked on my first one the other day. Gravity conversion. Funny seeing a litttle 80k boiler with 1” copper hooked up to 2 or even 3” header.
    hot_rod Member Posts: 25,354
    Call them heating appliances if they are not producing steam. And maybe also loosen up on the ASME H stamp requirements.
    HTP has made some excellent, buffered, radiant specific products over the years, but struggled with sales due to lack of inspectors insisting on the H stamp.
  • ChrisJ
    ChrisJ Member Posts: 16,852
    I've brought this up to the guys that give people a hard time over "hot water heater" but are perfectly ok calling something that doesn't boil a boiler.
  • ChrisJ
    An oldie but goodie
  • JUGHNE
    JUGHNE Member Posts: 11,461
    But all water heating appliances are capable of becoming a boiler.....not always good.
  • Solid_Fuel_Man
    Solid_Fuel_Man Member Posts: 2,644
    edited March 2020
    A water system:
    Circulating, single phase, sensible heat, transfer circuit, employing both heat generator, and heat rejection.
  • Canucker
    Canucker Member Posts: 723
    edited March 2020
    > @Solid_Fuel_Man said:
    > A water system:
    That's too long. Motion carried. Sissy water warmer it is!
    Next item on the agenda, please
    You can have it good, fast or cheap. Pick two
    ChrisJethicalpaul
  • Solid_Fuel_Man
    Sissy fuel saver!
    Canucker
  • neilc
    neilc Member Posts: 3,029
    kuz it's not a furnasty
    known to beat dead horses
    Solid_Fuel_Manethicalpaul
