Polysulfone fittings - you like them?
norfitz
My current PEX fitting manufacturer is transitioning to polysulfone fittings, and of course my customers will have to buy expensive new tools in order to use them. Anybody know if there is a particular manufacturer whom these other manufacturers are simply name-branding? Any other observations about polysulfone fittings?
Why would they need new tools? The fittings are either crimp or expansion, same as any other pex fittings and there are several MFG making poly fittings. I wouldn't use them in a stressed application as I've seen elbows break in half under stress, but they're honestly (my opinion) a better option than brass in most cases. With that said, I use primarily brass but that's ONLY for aesthetics2
Why would you put a fitting is a stress or potential stress condition? If not the fitting, the crimp connection would be compromised. I would think encased in concrete would be safer than brass sleeved where there could be flex or movement working on the connection.
It may take some years to know if any short comings of that material. Reminds me of the move from brass to acetyl fittings in PB systems
Living the hydronic dream1
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
