Trying to identify this item-gas?
  • JUGHNE
    JUGHNE Member Posts: 11,527
    edited March 2020
    Is it connected to those, what appear to be, water lines?
    And where do those 2 small copper lines go to?
  • Fred
    Fred Member Posts: 8,542
    It looks like a splitter of some kind but I doubt it is gas??? Doesn't look like it's connected to anything other than the one line. Is it just laying on the pipe, below it? What's on the backside of it?
  • HomerJSmith
    HomerJSmith Member Posts: 2,745
    A gas pressure regulator with an atmospheric vent?
    HVACNUT Member Posts: 7,310
    Who am I, Kreskin?
    What's under the foil and pipe insulation?
    Looks like a regulator.
    STEVEusaPA
    mattmia2 Member Posts: 16,043
    What does the end with the flange connections that looks like they are either blanked off or open look like?
  • Zman
    Zman Member Posts: 7,611
    A picture of the other side would help.
    Albert Einstein
    EdTheHeaterMan Member Posts: 11,765
    Is that an oil to gas conversion valve? or does it change water into wine? :D
    Need a picture of the other side!
  • JUGHNE
    Old school 100 pound LPG bottles sometimes had a special regulator connected to both bottles. It would somehow switch to your second bottle when the first run low.
    Those regs would have been outside at the bottles though.
    HVACNUT
  • JUGHNE
    I see now just one copper connected......the other is a mortar joint.....bad eyes.
    I just looked thru old 1980's Fisher and Rego catalogs and the auto change over regulators don't look like that.
    There are apparently auto change over regs for campers/RV's etc.
    Another oddity I have come across is some basements are mixing valves for WC supply. A little warm water into the tank keeps it from sweating.
    All those were brass though.
    I think those got coded out for energy standards etc.
    Now almost all houses have AC so tanks not sweating as much.
  • ChrisJ
    ChrisJ Member Posts: 17,162
    Until we get a picture of the other side, which probably has writing on it...........
    I don't see this going anywhere.
  • unclejohn
    unclejohn Member Posts: 1,833
    I think its part of the hookie pookie.
  • retiredguy
    retiredguy Member Posts: 1,084
    It looks like a very old pneumatic valve actuator. Is this thing in a large building with or at 1 time had pneumatic temperature controls
    ...just turn yourself around!
    Now that 's what it's all about!
    Knowing where that tubing goes seems important. Is it or was it attached to something in that location or did someone just shove the whole thing in the basement 50 years ago.
  • BillyO
    BillyO Member Posts: 277
    looks like its attached to bracket but not pipe
