Holohan Project
Paul Pollets
Member Posts: 3,671
It's a small world...a distant cousin of Dan's, who moved to Seattle from Ireland purchased a home nearby and wanted a good hydronic system installed. Her husband is a mechanical engineer and the system was fired up today. We used a Viessmann Vitodens 200 and a 53g indirect tank with 11 radiators, both Runtal and HeatLines with a 24"x70" towel bar warmer in the basement bath.
9
I love those expansion tank brackets. Nice clean install! What water temperature did you design for?Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
Was it in the back of your mind that Dan might make a visit
Nice sweats by the way ,can I ask what type torch tip do you use ? There was an error rendering this rich post.
You make us all proud, Paul. Thanks.Retired and loving it.0
Wow...small world!
President
HeatingHelp.com0 -
The unistrut bracket caps are a nice touch.0
