Holohan Project
Paul Pollets
Paul Pollets Member Posts: 3,671
It's a small world...a distant cousin of Dan's, who moved to Seattle from Ireland purchased a home nearby and wanted a good hydronic system installed. Her husband is a mechanical engineer and the system was fired up today. We used a Viessmann Vitodens 200 and a 53g indirect tank with 11 radiators, both Runtal and HeatLines with a 24"x70" towel bar warmer in the basement bath.
ethicalpaulSolid_Fuel_ManDan Foleymattmia2STEVEusaPAkcoppCanuckerDZoroSteve Minnich
  • Solid_Fuel_Man
    I love those expansion tank brackets. Nice clean install! What water temperature did you design for?
  • Big Ed_4
    Big Ed_4 Member Posts: 3,404
    Was it in the back of your mind that Dan might make a visit :) Nice sweats by the way ,can I ask what type torch tip do you use ?
  • BillyO
    BillyO Member Posts: 277
    what brand are those wall brackets?
    kcoppGrallert
    EBEBRATT-Ed Member Posts: 19,850
    Very nice job @Paul Pollets
    What was heating the house before the install?
  • Paul Pollets
    edited February 2020
    The expansion tank brackets are made by Flamco, the system design was for 140, and there was forced air in the home prior.
    BillyOCanuckerDZoroSuperTech
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,689
    You make us all proud, Paul. Thanks.
    Retired and loving it.
  • Erin Holohan Haskell
    Erin Holohan Haskell Member, Moderator, Administrator Posts: 2,363
    Wow...small world!
    President
    HeatingHelp.com
  • Gordy
    Gordy Member Posts: 9,546
    The unistrut bracket caps are a nice touch.
