Securing heat transfer plates
RedMonte85
Member Posts: 71
In an above subfloor application where I am trying to lay a vinyl plank floor directly over top of the tubing and plates, what is the best way to secure light guage heat transfer plates to the plywood sleepers without deforming them? Also, how many screws/nails/staples for a 2ft long transfer plate? 6 per?
Have about 800 sq ft give or take to do so I was thinking a pneumatic nailer/stapler.
Are they pre drilled?Bob "hot rod" Rohr
no they are not0
Hi Hot Rod.... I Watched and gather so much information for radiant heating..now i started to install Uponor wirsbro Joist track extruded aluminum plate...came with small size hole only 0.125" dia... can't fit any size of screw ...only #5 screw...i don't have any idea which fastener should i use for those plate for underfloor between joist installation...Any ideas and suggestions will be very helpful....
Please...
Thank you....
Hiren PatelThank you,
Hiren Patel0 -
I use a screw with a drill point. If you use a typical sheet metal or wood screw it ca push the plate off the wood. You want a tight fit to the wood for conduction transfer
With pre-drilled plates duct screws with well, with a magnetic chuckBob "hot rod" Rohr
How closely are you placing your screws to the tubing?0
Mid point between tube and edge. Try and see where you get the best pull downBob "hot rod" Rohr
Thank yo hot rod.Thank you,
Hiren Patel0 -
Why use Joist Trak above the subfloor? QuickTrak or Climate Panel is designed exactly for your purpose...0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
