Securing heat transfer plates
In an above subfloor application where I am trying to lay a vinyl plank floor directly over top of the tubing and plates, what is the best way to secure light guage heat transfer plates to the plywood sleepers without deforming them? Also, how many screws/nails/staples for a 2ft long transfer plate? 6 per?
Have about 800 sq ft give or take to do so I was thinking a pneumatic nailer/stapler.
    hot_rod Member Posts: 27,546
    Are they pre drilled?
  • RedMonte85
    RedMonte85 Member Posts: 71
    no they are not
  • hcpatel78
    hcpatel78 Member Posts: 157
    Hi Hot Rod.... I Watched and gather so much information for radiant heating..now i started to install Uponor wirsbro Joist track extruded aluminum plate...came with small size hole only 0.125" dia... can't fit any size of screw ...only #5 screw...i don't have any idea which fastener should i use for those plate for underfloor between joist installation...Any ideas and suggestions will be very helpful....
    Please...
    Thank you....
    Hiren Patel
    Thank you,
    Hiren Patel
    I use a screw with a drill point. If you use a typical sheet metal or wood screw it ca push the plate off the wood. You want a tight fit to the wood for conduction transfer
    With pre-drilled plates duct screws with well, with a magnetic chuck
  • RedMonte85
    How closely are you placing your screws to the tubing?
    Mid point between tube and edge. Try and see where you get the best pull down
  • hcpatel78
    Thank yo hot rod.
    Thank you,
    Hiren Patel
  • Paul Pollets
    Paul Pollets Member Posts: 3,672
    Why use Joist Trak above the subfloor? QuickTrak or Climate Panel is designed exactly for your purpose...
