electrolysis
MikeDurigon
Member Posts: 33
When connecting copper to steel do you need to use dielectric unions. I was told by an engineer that electrolysis does not exist in a heating system. I have tried to research this topic but have been unable to find any information supporting the engineers answer. Thank you.
With a closed system, electrolysis is nothing but a facade. A lot of makeup water will create issues without dielectric fittings, but a standard residential system dielectric fittings are nothing but trouble IMO0
Well, yes and no. Electrolysis will exist anytime two dissimilar metals are in contact with the same electrolyte and also electrically connected. Is it a problem in heating systems? Not really, by all the evidence.Br. Jamie, osb
Yes even similar metals can support electrolysis, old copper to new copper even, according to the Copper Development Association
Water with high TDS increases the “electrolyte” and the potential for electrolysis
In closed loop, sealed Hydronics the mixed metals should not be a concern
Adding a hydronic condition help protect all the metals also if you are concerned.Bob "hot rod" Rohr
Living the hydronic dream0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
