electrolysis
When connecting copper to steel do you need to use dielectric unions. I was told by an engineer that electrolysis does not exist in a heating system. I have tried to research this topic but have been unable to find any information supporting the engineers answer. Thank you.
  • GroundUp
    GroundUp Member Posts: 2,518
    With a closed system, electrolysis is nothing but a facade. A lot of makeup water will create issues without dielectric fittings, but a standard residential system dielectric fittings are nothing but trouble IMO
    Jamie Hall Member Posts: 27,459
    Well, yes and no. Electrolysis will exist anytime two dissimilar metals are in contact with the same electrolyte and also electrically connected. Is it a problem in heating systems? Not really, by all the evidence.
    hot_rod Member Posts: 27,617
    Yes even similar metals can support electrolysis, old copper to new copper even, according to the Copper Development Association
    Water with high TDS increases the “electrolyte” and the potential for electrolysis
    In closed loop, sealed Hydronics the mixed metals should not be a concern
    Adding a hydronic condition help protect all the metals also if you are concerned.
