Pressure Pal
Member Posts: 4,644
Has anyone used the Axiom Pressure Pal as a water feed for hydronic systems? It seems like an innovative product and could save a lot of money in jurisdictions like San Francisco that require an expensive RP device backflow preventer along with yearly, expensive backflow certification.
I love them, the price has even come down a bit since the first one I put in. They are perfect when there is glycol in the system and as you said you dont want a RP device that will need testing.
State of vermont just told us they want NOTHING in the system except water, or you gotta have the RPZ. So I asked if I had a plugged system and need to clean it, then flush, they said would need an RPZ. I got a bit sad.
I understand what they are trying to do, but common sense has to prevail. Tom
Montpelier Vt1 -
Used them on commercial settings. Good way to monitor any water use.0
- 167 Indoor-Air Quality
