Something new?
This is probably from the makers of the 200 mpg carburetor:
oxicool.com
    Jamie Hall Member Posts: 27,280
    There is no free lunch... at some point in the cycle, one is going to have to add some energy to rejuvenate the molecular sieves. They seem to be a little coy about that.
    One might compare the whole concept with the gas fired ammonia adsorption refrigerators.
  • ChicagoCooperator
    ChicagoCooperator Member Posts: 363
    Wasn't gas central air conditioning somewhat common in it's early days (like up to the 50's)?
  • ChrisJ
    ChrisJ Member Posts: 17,321
    I was thinking about solar powered absorbtion air conditioning the other day.
  • KC_Jones
    KC_Jones Member Posts: 5,931
    "The base MSRP for a 20,000 BTU/hr system with four in home heat exchangers is estimated at $10,000."
    Yikes.
    2014 Weil Mclain EG-40
    EBEBRATT-Ed Member Posts: 20,103
    Arkla made absorbtion airconditioning/heating units they were pushed by the gas company back in the 60s.
    They used ammonia for refrigerant and the units are extremely heavy for there tonnage. They were a combination water chiller/hot water heating unit. They ran an open system and you had to use glycol as they are located outdoors.
    Now the name is "Robur" and they are still made.
    I installed a couple of these back in the 90s
    If you had to break into or work on the sealed ammonia system they were a nightmare
  • ChicagoCooperator
    How would that work at night?
  • ChrisJ
    > (Quote)
    Electric or gas heater.
