Wireless Outdoor Reset Sensor
delta T
Member Posts: 884
I have a boiler replacement coming up that is going to necessitate using a modcon, but primarily for space saving reasons. The existing boiler rooms are too small to allow anything else. Since I'm going to have them there, I'd love to use an outdoor reset curve to save them some money, but don't have any practical way to run the wire. Anyone ever find or use a wireless sensor for this? I can't seem to find any wireless solution for this, though it seems like there should be something in this day and age....
Can you sneak a wire inside the intake pipe?
D0 -
@DZoro in this case it is not practical, as the makeup air will be going to the roof. I don't think I will get any kind of accurate reading anywhere. (dark color, no shade, etc.). This is an apratment building with 16 units. Actually its 3 identical buildings with 16 units each. I need 3 sensors total.
@HVACNUT I haven't found any tekmar solution yet, but I'm still looking....0 -
I was almost to the point of trying to make one using an arduino and some wifi setup...this is so much better0
Will do.0
