Thermostat that will hold for a set time
Hi folks,
Sorry if this has been asked before. I couldn't find a thread. I'm looking to buy a thermostat with a feature that will hold on a timer. This is different from a temporary hold which only lasts until the next schedule change. Basically, I want to hit hold, enter a duration (eg 2 hours) and walk away.
Does anyone know a way I can do this? Thanks.
    HVACNUT Member Posts: 7,175
    Honeywell Prestige IAQ
    DPronto
  • ratio
    ratio Member Posts: 4,168
    In addition to the Prestige the 8000 series, when set to commercial mode, offer a timed override. A commercial use version of the Carrier Edge Pro will do it too. I dare say most commercial-type stats will function that way.
    DPronto
  • DPronto
    DPronto Member Posts: 7
    Thanks guys, if that's the case I should be sitting pretty.
  • pmarinello489
    pmarinello489 Member Posts: 23
    any of the honeywell T thermostats do it. T5 to the T10 I am almost certain. At least with my experience t5, t6, t9, and t10 all have the feature.
