Tank, tankless or indirect
zvalve
Member Posts: 83
I am from the school of learning by doing. How hard is it to do a diy install on a tankless hot water heater. How do you Size the gas pipe for the unit? Should I contact my gas company? What about a diy install of an indirect water heater? I have a Dunkirk PVWB-4D boiler, natural gas, 105000btu/hr input, 84000 btu/ hr output. It old but can I add another zone to that? Which means shutting down an draining boiler? But I kind of have an emergency with a tank hot water heater and have a rental apartment in the same house so maybe I should do a quick and dirty new install of a cheap tank water heater and wait for warmer weather to do something more complicated.
Kind of a loaded question, What kind of DIY projects have you successfully tackled? Tankless heaters can have challenging venting and gas pipe sizing issues. I would not doing your first boiler drain/ repipe job in the winter without "plan b" in place?"If you can't explain it simply, you don't understand it well enough"
Albert Einstein1 -
Since you already have the boiler my first choice would be an indirect. It will involve some piping and control work.
If you need it quick and easy, and have a breaker panel nearby an electric tank, does the renter pay electric?, until you have time to do a repipe on the boiler for an indirect.Bob "hot rod" Rohr
I’d you are descent at sweating copper, indirect isn’t too hard to install. Just follow the manual.0
