Steam coming out of radiator vent
Hi everyone, I've been looking at this discussion and I'm hoping you guys can help me. I'm a girl so I have no idea about radiators so please be kind...lol.. my radiators look a lot like the one posted above. one of my upstairs bedrooms the steam coming out of the vent is destroying my plaster wall.. do I need to replace it? Or change the number setting on it? It's the smallest spare bedroom upstair and no one goes in it.. I also dont know what the numbers mean either.. what should they all be set on? Any help would be great!! Here is a pic.0
@gfrbrookline It seems like more work to swap radiators (if you have spares) than to just put in a Vent Rite #1. Unless someone installed an oversized radiator, swapping around shouldn't be necessary.0
Hi there-- Don't worry about being a woman, most men are clueless when they first come here too (I sure was). Yes, I'd replace it. It is supposed to be closing when it sees steam, not letting the steam come out. How many decades has it been leaking?jess32777 said:Hi everyone, I've been looking at this discussion and I'm hoping you guys can help me. I'm a girl so I have no idea about radiators so please be kind...lol.. my radiators look a lot like the one posted above. one of my upstairs bedrooms the steam coming out of the vent is destroying my plaster wall.. do I need to replace it? Or change the number setting on it? It's the smallest spare bedroom upstair and no one goes in it.. I also dont know what the numbers mean either.. what should they all be set on? Any help would be great!! Here is a pic.
Since no one goes in that room, I would replace it with a vent that releases air slowly, like a Maid O' Mist #4 or if you have a lot of money, a Gorton #4.
Your existing vent is adjustable, so it can be adjusted by the room occupant to deliver heat faster, or slower. But all that is moot if it is leaking steam. It could might possibly be coaxed to work again, but since a MoM vent costs less than two lattes, that's the direction I'd go.
But also it's best to start a new discussion for a new topic, otherwise it gets very confusing. I bet @Erin Holohan Haskell will be happy to move your question to a new discussion for you.NJ Steam Homeowner.
Are you sure the nest is not working off it's preset set back schedule. Definitely move the tstat to a more average temp location.John Cockerill Exquisite Heat www.exqheat.com Precisions boiler control from indoor reset.0
Is this puppy short cycling due to pressurtrol settings? Seems kind of tight. A properly located thermostat should control the system. At Zero+ oz's pressure the steam should fill rads ?John Cockerill Exquisite Heat www.exqheat.com Precisions boiler control from indoor reset.0
Mine are all ⅓.SteamingatMohawk said:The vent valve looks a bit low, like about 1/3 of the height of the radiator. I can't determine if there are additional plugged openings. Conventional wisdom is to locate them half way up.
You might try setting it to a low number first. Unscrew the top completely and turn the piece below it until the hole to the side is almost (or completely) covered. (The radiator will then heat slower if at all.)
I used to have one of these leakers. If I remember right, it worked ok if it was set low enough. But then the radiator heated too slowly, so it became a spare.0 -
Thanks, @ethicalpaul.
@jess32777, we've opened up a new post for this discussion.President
HeatingHelp.com0 -
I give up. Where is the new post?
You're on it?
Right here.SteamingatMohawk said:I give up. Where is the new post?
Yes, this is the new post.
President
HeatingHelp.com0 -
- 50 Industry Classes
