matching suppy and return size
wayneman
in Gas Heating
I have 1 unit apt. with forced air heat.Furance is in basement. Some rooms have 2 supply lines with floor vents and some have one. The return is one floor return in a room without supply line( kitchen). I would like to add cold air returns in as many rooms as possible. I have read using floor joists is not the right way to go because hard to get good seals.Should returns pipe sizing match supply size?? example. if room feed with 2- 6" duct it looks like 1-8" return would handle about the same volume of air. any thoughts??
sealed Joist??
round vs. Rectangular piping
tin vs. flexible insulated tubing??
sealed Joist??
so I have to Hire someone to calculate those?? duct work air volume in- matching duct work air volume return does not work?? 6" duct air flow 120cfm x 2 ducts means 8" duct air flow 300cfm would handle return.0
I have ordered a big Mouth vent and want to install correctly. The attached pictures show where it would be located. can I directly put 90 in end of 2" main pipe or do I need 8-10" vertical extension then the 90 degree elbow? what difference does it really make?
-1 -
Yes the size of warm air returns should match the supplies. 6"round 100cfm, 7"150 8"200 10"4000
- 87.8K THE MAIN WALL
- 131 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
