Help with steam trap replacement
BaptistChurchOakPark
Member Posts: 3
I need help finding replacements for the following steam traps. They are leaking around the covers. I’m under the assumption that the threads (or bolts) are stripped.
¾ inch dunham #4
½ inch dunham v2-v3
¾ inch barnes and jones 2136
¾ inch barnes and jones 1990
½ inch barnes and jones 1964
¾ inch dunham #4
½ inch dunham v2-v3
@BaptistChurchOakPark , the covers might just need tightening. Or, the system may be running at too high a pressure. Or both.
Where is your Oak Park located?All Steamed Up, Inc.
Consulting1 -
Oak Park IL, just outside of Chicago.
I'll send barnes and jones a message. I have talked to them previously and found that dunham #4 is no longer being made.
The covers have been tightened but some of them keep coming loose. this and one of my 2 boilers is over filling for some reason.
I'm thinking that some of these steam traps are broken closed or possibly a condensate return line is plugged causing condensate to return too slowly? I have also never cleaned the cleanouts and niether did my old boss. So the cleanouts at elbows havent been cleaned out as far as i know for at least 25 years. The water level in the sight glass never changes however.
I'll try and figure out the operating pressure.
You have one of the best steam pros right in your area: @The Steam Whisperer . Give him a call:
https://heatinghelp.com/find-a-contractor/detail/the-steam-whisperer-boiler-professionals-incAll Steamed Up, Inc.
Consulting1
- 50 Industry Classes
