hot water priority
dhastings
dhastings Member Posts: 4
I HAVE AN EK accel cs ek1 propane boiler. Is it better to have hot water priority on or off??
    Jamie Hall Member Posts: 27,376
    Is this application just for heating, or do you also heat your domestic hot water with it?
  • Zman
    Zman Member Posts: 7,609
    It really depends on how your system is setup. If you have a low temp radiant system with outdoor reset domestic priority is a must. If you are running a fixed high temp system it probably doesn't matter.
    Albert Einstein
