hot water priority
dhastings
Member Posts: 4
in Oil Heating
I HAVE AN EK accel cs ek1 propane boiler. Is it better to have hot water priority on or off??
Is this application just for heating, or do you also heat your domestic hot water with it?Br. Jamie, osb
It really depends on how your system is setup. If you have a low temp radiant system with outdoor reset domestic priority is a must. If you are running a fixed high temp system it probably doesn't matter."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0
- 120 Geothermal
