Pipe insulation (and any alternatives to fiberglass?)
msmor23
Member Posts: 14
Hi- I need to insulate some of the pipes in basement for my one pipe steam system. Like most, I'm trying to save a buck so curious if there are any cheaper alternatives to the fiberglass pipe insulation. I have about 100' I need to insulate (1.75 OD).
I know the grey foam tubes aren't any good for steam pipes.
Also- any ideas on insulating pipes located within a chase? Without ripping apart the chase or walls?
Thanks for the help
Thanks for the help
Really fiberglass is the only choice although I have seen some with green insulation more like mineral wool but I doubt it's any cheaper.
Access to the bottom or top of the chase you may be able to slide it on but if you have fittings in the way there are no tricks
Check to make sure you pipes are pitched right and have enough hangers before you insulate1 -
Some people have used regular fiberglass insulation or duct wrap as a low-buck alternative and just wrapped it around their pipes and taped it. Not worth the frustration if you ask me, and it isn't going to look great, but it should provide decent insulation.Just another DIYer | King of Prussia, PA
What about old fashion newspaper?0
I bet Ed didn't mean it would burn from the steam, I bet he meant it would make a house fire much worse if one were to occur.
Edit: plus it's a horrible insulator!NJ Steam Homeowner.
Thanks for the help & suggestions.0
- 120 Geothermal
