Direct On-Demand DHW with Weil McClain Ultra 155
bzevotek
Member Posts: 2
I had an indirect on the DHW priority 1. I replaced it with an electric On-Demand that occasionally trips the breaker when it draws cold well water in the winter. Can I just flush my boiler and use the priority 1 for a DIRECT on-demand DHW supply (open loop system)? All of my other loops can be run at close to the same temperature (Mid 120's)? My boiler is undersized for my house and we are superinsulated.
I am not sure why you switched away from the indirect and went to electric. Now that you have the electric, why is it tripping the breaker? The unit should have an amp rating and the circuit should be sized accordingly. If you post all the details, we can attempt to get you out of trial and error mode."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0
- 116 Geothermal
- 169 Indoor-Air Quality
