Can I separate the radiant manifolds?
Las
Las Member Posts: 1
I am a newbie diyer, installing Caleffi (S1 series) inverted manifolds in the joist space under the subflooring. In one location I am limited with install options and want to "separate" the hot-supply manifold from the cold-return manifold. The system comes pre-assembled with a hanging bracket keeping them parallel. I want to cut the bracket and mount them in-line. The pex tubing length would essentially be almost the same. Can I do that? I can't see why not, wanted to ask if anybody knows otherwise and I am missing something. Thanks
  • Ironman
    Ironman Member Posts: 7,901
    Sure.
    Bob Boan
    Las
    hot_rod Member Posts: 27,322
    Or unbolt them from the bracket and build another mounting method
    Once you cut that factory bracket it will be flimsy and not very user friendly
    Las
