Radiant floor sensor
Gta
Gta Member Posts: 151
Hi folks
I’m currently using rehau dual sensing t stats , could I just set them to use floor sensor only?
I find with using the air sensor it keeps turning the boiler on often .... I was hoping that if I set it to only use the floor it would turn on less and save some energy by running for longer periods but less often ,
Thx Sean
  • Zman
    Zman Member Posts: 7,611
    Is the boiler cycling because it has satisfied its operating temp or is it cycling because the t-stat is satisfied?
    Albert Einstein
  • Gta
    Stat
    The house just cools down fast
    hot_rod Member Posts: 26,507
    The rate at which a room or home looses heat is more about insulation and air leakage. any gaps under exterior doors, around windows, framing in crawl or basement.
    Check into having a blower done test to identify air leakage "infiltration" this could solve loss or heat, and increase comfort and reduce heat bills.
    A floor sensor alone in not usually the best control for a home comfort system, it doesn't know or respond to ambient temperature conditions.
    The stat may have some adjustment to spread the on/ off differential maybe 1 or 2 degree? If so try adjust that a bit wider.
  • Gta
