Radiant floor sensor
Gta
Member Posts: 151
Hi folks
I’m currently using rehau dual sensing t stats , could I just set them to use floor sensor only?
I find with using the air sensor it keeps turning the boiler on often .... I was hoping that if I set it to only use the floor it would turn on less and save some energy by running for longer periods but less often ,
Thx Sean
Thx Sean
Is the boiler cycling because it has satisfied its operating temp or is it cycling because the t-stat is satisfied?"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Stat
The house just cools down fast0 -
The rate at which a room or home looses heat is more about insulation and air leakage. any gaps under exterior doors, around windows, framing in crawl or basement.
Check into having a blower done test to identify air leakage "infiltration" this could solve loss or heat, and increase comfort and reduce heat bills.
A floor sensor alone in not usually the best control for a home comfort system, it doesn't know or respond to ambient temperature conditions.
The stat may have some adjustment to spread the on/ off differential maybe 1 or 2 degree? If so try adjust that a bit wider.Bob "hot rod" Rohr
Hitting it with this ... gotta help I hope0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
