Taco HEC-2 Bumblebee Buttons not working?
hotsauce
Member Posts: 20
I have a quad using 8 Taco bumblebee's in its heating system. I recently decided to change 4 of the pumps from delta-T to SP mode however none of the 4 pumps I tried to change the programming on will respond to any button pushes. These pumps were installed in a 2016 upgrade so they arent that old. Anybody else encounter this problem or have any suggestions on how to fix? Thanks!
Please call into Taco Tech Support at 401-942-8000 and to help find a solution to this issue.0
Good morning Hotsause
I'm following up on this. can you provide some feed back for the team? I asked Steve from Taco tech support to reach out to you for better Customer service, but at the same time, this is an awesome forum for learning:)
I know from my previous experience with HEC, is those buttons can be finicky, and I'm guessing that's what it was. thanksJoe Mattiello
Taco Comfort Solutions1
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
