Taco HEC-2 Bumblebee Buttons not working?
hotsauce
hotsauce Member Posts: 20
I have a quad using 8 Taco bumblebee's in its heating system. I recently decided to change 4 of the pumps from delta-T to SP mode however none of the 4 pumps I tried to change the programming on will respond to any button pushes. These pumps were installed in a 2016 upgrade so they arent that old. Anybody else encounter this problem or have any suggestions on how to fix? Thanks!
  • SteveSan
    SteveSan Member Posts: 293
    Please call into Taco Tech Support at 401-942-8000 and to help find a solution to this issue.
  • Joe Mattiello
    Joe Mattiello Member Posts: 748
    Good morning Hotsause
    I'm following up on this. can you provide some feed back for the team? I asked Steve from Taco tech support to reach out to you for better Customer service, but at the same time, this is an awesome forum for learning:)
    I know from my previous experience with HEC, is those buttons can be finicky, and I'm guessing that's what it was. thanks
    Joe Mattiello
    Taco Comfort Solutions
