residential steam return line
keith_27
keith_27 Member Posts: 64
any tricks off the trade for a partly clogged 1" return line. Half of the line is behind paneling but only one radiator does not heat . Was going to install a vent at the end of the main but took the nipple out and had water.
    Jamie Hall Member Posts: 25,957
    You are going to have to try to flush it out, which may be much easier said than done. Depends on where, and at what kinds of fittings, you can get at it.
