Type IV Boiler vent
newinnj
newinnj Member Posts: 64
edited November 2019 in Radiant Heating
Hi,
I have a Navien NB-150 condensing boiler. The boiler vent collars have a tiny gap between the collar and the boiler. First should this be sealed? I am thinking yes. If so, any recommended material to seal the gap. Thanks in advance.
  • JUGHNE
    JUGHNE Member Posts: 11,523
    Open it up and look inside. Are there solid pipes passing thru the collars? The gas may be only on the flange and not the actual pipe itself.
  • newinnj
    You are correct and thanks! Pipes inside the boiler goes up and past the collars into the external pipes.
