Honeywell 700-107 replacement valve
eric50158
eric50158 Member Posts: 3
I've been told that the valve in my Kozy Heat fireplace needs to be replaced, but Honeywell no longer makes the part (id 700-107 natural gas). Tech is saying entire fireplace unit will need to be replaced. If I need to spend a few hundred dollars on replacement or retrofitting the valve assembly, so be it, but having to replace the entire fireplace doesn't make much sense to me. Anyone able to chime in on the extent of replacement needed, or suggestions on replacement valves?
Thanks in advance.
    Steamhead Member Posts: 18,186
    Sure that's not a Robertshaw valve? The model number looks like one of theirs...............
    Consulting
    JUGHNEeric50158Intplm.delta T
  • eric50158
    I double checked to confirm, it is a Honeywell
    HVACNUT Member Posts: 7,211
    Have you tried contacting Kozy Heat?
  • eric50158
    I have a call into them - Kozy Heat requires I go through a local rep, and most local reps only will service (or even discuss) units they have sold and installed - I'm not the original owner so hard to tell who that would've been. I'm still trying, but am also researching SIT valve replacement kits, though have yet to find one that directly translates to a 700-107 replacement.
  • JUGHNE
    JUGHNE Member Posts: 11,508
    A picture of valve showing connections and mod numbers might help.
    HVACNUT
  • Tim McElwain
    Tim McElwain Member Posts: 4,657
    Show a picture because I feel that is a Robertshaw valve!
    JUGHNE
  • ch4man
    ch4man Member Posts: 297
    edited November 2019
    sorry, thats the infamous honeywell RF valve. made for many fireplace manufactures not just Kozy. then abruptly HW just stopped and never made a replacement. just got out of the fireplace specific valves altogether (they still may make low capacity gas valves for space heaters that will work in some fireplaces, but not yours)
    for others reading the RF valve has a built in board the controls flame height and fan speed as well as temperature. board and valve cannot be separated. very unique and special part. too bad HW just left many hanging including many dealers with warranties that couldnt be kept
    sorry
    delta Teric50158
  • Intplm.
    Intplm. Member Posts: 2,818
    Try Calling honeywell for their recommended replacement
  • delta T
    delta T Member Posts: 884
    Yeah, just did some digging, looks like @ch4man is correct. There is not any replacement for that valve, and as far as I can find Honeywell did not make a replacement. Sorry to say, but it seems like you are looking at replacing the whole unit.
    eric50158
  • Tim McElwain
    Send a picture as I may be able to recommend a replacement so you do not have to buy a new unit.
    delta T
  • p4nier
    p4nier Member Posts: 1
    edited December 2020
    Posting here to see if OP had any luck with a conversion kit, as I'm in the same boat. Princeton PRC-36-RF fireplace with Honeywell RF Valve 700-107 (Natural Gas). Replaced both thermocouples hoping that would solve the problem, but no luck. Picture of the valve attached. Would really love to avoid replacing the entire fireplace if there is an option. I'm OK with losing the remote control and other functions. Just want to be able to turn flame on and off. Any guidance is greatly appreciated!
  • Tim McElwain
    I suggest you get in touch with Princeton Kozy Heat and see if they can help you find a replacement.
  • coachlou
    coachlou Member Posts: 1
    Nov. 2, 2021; I have the same problem, pilot won’t stay on. Thermopiles are fine, 760 and 755 millivolts output. Trouble shooting points to a bad solenoid. The pilot was off for the summer so the solenoid might be stuck in the closed position. Can this be opened, rebuilt/replaced within the valve unit? We need a schematic to open the valve and get to the solenoid but unable to find a schematic anywhere. Coachlou
    EBEBRATT-Ed Member Posts: 19,487
    @coachlou
    Working on gas valve internals is a good idea. Too much liability. I would suggest trying Robert Shaw or another valve mfg for a replacement
  • neilc
    neilc Member Posts: 3,111
    I think you're missing a NOT,
    @coachlou
    Working on gas valve internals is (NOT) a good idea. Too much liability. I would suggest trying Robert Shaw or another valve mfg for a replacement
    known to beat dead horses
    EBEBRATT-Ed
  • TonyPipes
    TonyPipes Member Posts: 5
    I have smacked old gas valves with a wrench and they opened back up. Believe it or not it works sometimes. Don't be gentle, what's the worst that happens it breaks?
    mattmia2 Member Posts: 15,497
    worst that can happen is it stick open at some later point.
  • reko19
    reko19 Member Posts: 1
    edited February 2022
    Hi everyone, I also have Kozy Heat with Honeywell RF Valve 700-107 (Natural Gas). Replaced both thermopiles, pilot is still not staying ON. A couple of conversion kits I was able to find are fairly expensive, not sure if it makes sense to go that route or replace a fireplace all together. If I am willing to give up RF remote control capabilities, can I replace the honeywell valve with a different one? Anything else I could do trying to get it to work in addition to replacing both thermopiles? Thanks everyone.
