Looking for a replacement Gas Valve
Crashland
Member Posts: 3
in Gas Heating
Hello I have a 1958 Bryant FH water boiler. It has a magnetic diaphragm valve Bryant Model A635 that sticks on the
closed or half open position. When it sticks I give it a little tap with a golf club and it opens all the way. I know it is old but runs fine except for the valve sticking. I have looked at the Robertshaw line of valves but not sure which one to pick. On SS hate to have to get a new boiler. Thanks in advance
Pictures of the existing gas valve and piping....include the pilot line and what controls it.
How many BTUH input is the boiler?0 -
Does the pilot tubing come off the gas valve or is it separate, off the cock? If the latter, there will be some retrofitting to do.0
Also ... Are you using an iron or a wood to get the valve to open the rest of the way?
Thanks I understand0
We had a 200K boiler in the family home in the 80s, boiler from the 50s. Gas valve stuck on. Dad was home. Thought the place was blasting off to the moon. He doesn't know which end of a screwdriver to hold but managed to get the gas off. A year later the boiler split open. Seems to me time to put that relic out to pasture or at least not use til the valve is replaced.1
- 167 Indoor-Air Quality
