Adding a second riser to boiler
Itmejvt
Member Posts: 4
Hey all, I want to add a second riser to my Weil McClain boiler. The boiler has two punch out sections for risers. I believe this will lead to better steam quality. Is this a complicated fix? Thank you
To add a second riser is not advisable. If you do not have problems and it ain't broke don.t fix it.
The second riser will need a complete work up of the piping leaving the boiler. Lot of work and possibly money.
Jake
Steam: The Perfect Fluid for Heating and Some of the Problems
by Jacob (Jake) Myron0 -
Pictures showing all existing piping from floor to ceiling will get some attention here.0
It's worth looking at the install manual for your boiler to see what the manufacturer recommends. Of course more can be better, but is there a specific issue you are trying to solve?
See my sight glass boiler videos: https://bit.ly/3sZW1el1
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 163 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
