Two pipes on a one pipe system
jewett44
Member Posts: 3
I have a bathroom in my house were the previous owner took out the radiator and now its freezing. The supply pipe is still under the bathroom capped off. I have a lot of 1/2" copper pipe and I was brainstorming how I could use it on my one pipe system. Since 1/2" is rather small I thought that steam and water cannot pass each other, at least not without a lot of water hammer. So in my diagram attached I am proposing a 2 pipe connection were steam comes in and since the radiator is pitched the water will return through the other side. In the return side there will also be a bend in the pipe acting as a water trap. So steam won't try to go through the return pipe. Let me know what you think and if it might work.
Question: why not just restore the original size feed to a one-pipe radiator?
1/2” piping is to small and copper piping and fittings will eventually leak due to expansion and contraction rate.
Do you know what the square footage of steam that the radiator you have is rated for? Based on the square footage output of the radiator then you determine what size riser pipe you’ll need with a properly sized valve.0 -
> @ethicalpaul
I could do that and that would be what I would do if this wasnt possible. I was just brainstorming alternative methods. More or less because I wanted to know if it was possible.0 -
Yes 1/2” piping is to small even if it’s copper or steel. You don’t want to use galvanized piping and fitting you’ll want to use steel pipe mailable or cast fittings.0
Be careful on selecting your radiator. Try to find an old one that was meant for steam.Burnham IN5PVNI Boiler, Single Pipe with 290 EDR
18 Ounce per Square Inch Gauge
Time Delay Relay in Series with Thermostat
Operating Pressure 0.3-0.5 Ounce per Square Inch0 -
CastRads looks pretty cool.
I recently used Ecorad to get some refurbished radiators that matched the rest of the radiators in my house for some remodeling we did.Burnham IN5PVNI Boiler, Single Pipe with 290 EDR
Operating Pressure 0.3-0.5 Ounce per Square Inch1
- 87.1K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
