Boiler Replacement
Dan Foley
Member Posts: 1,255
Thank you @ Ironman (Bob Boan) for the referral.
We replaced the boiler in this c. 1870 home in Falls Church, VA.
The old compression tank above this WM boiler waterlogged and broke from its mounts. This snapped the connecting copper pipe flooding all of the electrical components. Time for a new boiler.
1
We had one surprise. The old chimney did not have a clay tile liner. It had been lined with B-Vent at some point in the past.
One of the joints worked loose and flue products were leaking into the space around the chimney. This completely rotted out the B-Vent.
We scrambled to find a stainless steel liner so we could complete the job. Luckily RE Michel had one in stock.0 -
Beautiful as always Dan.
@Mike_Sheppard...here's one:
https://s3.amazonaws.com/s3.supplyhouse.com/product_files/97976-Flamco-Product-Overview.pdf Fits between floor joists too.steve1 -
@ Mike Sheppard
It is a Flamco expansion tank bracket.0 -
HE II. We had one in the family home just before the folks moved. Loud as an oil burner. Quite a change from the old National US Radiator boiler from the 50s. Converted gravity, no bypass, wonder how long it lasted. The old one turned into a steamer when the gas valve stuck open and split a year later.1
@ jerryb46
Thanks for the comment. All of our wiring is MC armored cable. What you see on the right side is not Romex but flexible CSST gas line feeding the water heater. This was existing work by the plumber.0
- 84.3K THE MAIN WALL
- 53 Biomass
- 417 Carbon Monoxide Awareness
- 44 Chimneys & Flues
- 1.8K Domestic Hot Water
- 4.8K Gas Heating
- 120 Geothermal
- 156 Indoor-Air Quality
- 3K Oil Heating
- 57 Pipe Deterioration
- 795 Plumbing
- 5.4K Radiant Heating
- 371 Solar
- 14.1K Strictly Steam
- 3.1K Thermostats and Controls
- 39 Industry Classes
- 80 Job Opportunities
- 22 Recall Announcements
