Where is all the water?
6-8 gallons a day is a massive insane amount of lost water and the buried wet return is a suspect, for sure. How do/will you keep your house from freezing when you leave for 3 days?
Note: if I had a guy tell me that all boilers were different and therefore 6-8 gallons per day might be normal for me, I would laugh him out of my house and tell everyone I knew not to use him.
Does the burying look “optional”? Like could the return be repiped lying on the floor?NJ Steam Homeowner.
I am definitely considering piping on the floor and not digging when I can afford it, but even then, I'm worried about underneath the house - especially when there don't seem to be any signs of a problem (yet). I know the 'normal loss' comments were BS, but steam guys are few and far between in mid-Michigan. Re: keeping my house "from freezing when you leave for 3 days"? I'm guessing this is how long it might take to plumb new pipe? Thanks0
Getting kind of chilly, so the obvious test may not be usable: if there is a leak under the floor, it will keep going until the water level in the boiler drops to the Hartford Loop. In fact, that's what the Hartford Loop is for. So... if you fill the boiler a couple of inches above the bottom of the Hartford Loop and keep an eye on it and the water level drops with the boiler off but stops at the Loop, most likely that's the problem. Not that there couldn't be a leak into the firebox at just that level -- coincidences do happen -- but take the simplest solution first.
Now a couple of other thoughts. First, there's no problem running a new wet return across the floor, and a good plumber or steam man should be able to make the switchover from one to the other in a few hours at most -- having already run the pipe, of course. So you wouldn't be without heat for long enough to make a difference.
Second, a few hundred gallons leaking under a house sounds like a lot -- but from the standpoint on the house itself, unless it is concentrated in a stream (it wouldn't be) it's not much. In very round numbers here, say we are concerned with about 800 gallons of water over a year's time. That's around 100 cubic feet per year. Now if the house is about 20 feet square (kind of small, but a handy number, that means that each square foot of soil under the house is getting around a quarter of a cubic foot per year or the equivalent of 3 inches of rain -- per year. That won't show up outside the house (it rains more than that, unless you're in the southwest somewhere) and won't reduce the strength of the soil under the basement slab much, if any. So... not to worry.
Going back to the boiler and the leak, though, that much fresh water feed into the boiler isn't going to do it any favours at all, and it would be worth finding the leak and fixing it.Br. Jamie, osb
Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England3 -
I have a call into a regular plumber and can hopefully get a decent estimate. From a previous post of mine, I know that since it's the return, a regular plumber can do it. Are there any steam-specific issues that a plumber may need to be aware of for this versus a steam expert?0
Interesting observation. We get about 35 inches of rain (not including 30+ inches of snow) per year, so thank you so much for that 'peace of mind' until I get this fixed. I'm glad I got the pipe leak fixed, but I'm convinced the water loss is occurring underneath. My house does not have a slab, but rather a somewhat thin layer of concrete poured over dirt (not skimmed or leveled) and the basement itself remains dry, so I'll keep my fingers crossed...Jamie Hall said:Second, a few hundred gallons leaking under a house sounds like a lot -- but from the standpoint on the house itself, unless it is concentrated in a stream (it wouldn't be) it's not much. In very round numbers here, say we are concerned with about 800 gallons of water over a year's time. That's around 100 cubic feet per year. Now if the house is about 20 feet square (kind of small, but a handy number, that means that each square foot of soil under the house is getting around a quarter of a cubic foot per year or the equivalent of 3 inches of rain -- per year. That won't show up outside the house (it rains more than that, unless you're in the southwest somewhere) and won't reduce the strength of the soil under the basement slab much, if any. So... not to worry.
No, I was mistakenly thinking you didn’t have an auto-feeder. I would think a new return could be plumbed in less than a day depending. And for sure the actual switchover time where they’d tie it in (with boiler turned off) a small part of the total timeNJ Steam Homeowner.
See my sight glass boiler videos: https://bit.ly/3sZW1el1
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
