Piping that goes to radiator are to high
Steam or water? Makes a difference. Can you put shorter nipples on the risers coming out of the floor?Br. Jamie, osb
Hot water Boiler. Thinking about just making the pipes shorter0 -
That's what I would do. Cut the piping down. Use fittings to fit to the lower dimension.Dairon421 said:> @Jamie Hall said:
Copper piping ? Baseboard radiation ?
Hang the new baseboard radiation a little higher and then fit to the supply and return.
> @Intplm. said:
> (Quote)
Black pipe. They using cast iron radiators0 -
Stolen cast iron radiators . And one would think it was stolen copper fin tube radiation $$.
Maybe a combination of raising the rads and lowering/cutting the piping.0 -
Yeah i was thinking about using a radiator elbow union and have it angled up,then i just put in a nipple i need so I can get to the same height of the piping.1 -
If the inlet/outlet valves are higher than the rad connections, you risk an air pocket that may stop the water flow.
There was a posting here where that may have been the problem with some BB convectors. The convectors could possibly have a higher flow that might have moved the air on thru. Your CI rads could be a slower flow that may not move the air bubble thru. And IIRC you will have 2 high points at each rad.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
