Troubleshooting Expansion Tank
Dairon421
Dairon421 Member Posts: 81
Is there any other way to tell if the expansion tank is bad besides knocking on it?
  • Zman
    Zman Member Posts: 7,609
    Much better! Remove the tank and check the precharge pressure using the schreader valve.
    Albert Einstein
    STEVEusaPA
  • STEVEusaPA
    That’s pretty much the only way.
    Same people who knock on expansion tanks must’ve learned it from knocking on oil tanks..
    Intplm.
  • Intplm.
    Intplm. Member Posts: 3,014
    Can sometimes push on the stem of the schrader valve. If you get air the bladder is most likely intact. If you get water, it's time to change it.
    ZmanDZoro
