Need your thoughts.
SeanBeans
Member Posts: 520
Gravity hot water system.
New cast iron boiler.
Primary secondary piping.
Side arm off of this boiler.
....pool heater off same boiler.
Please chime in with whatever your thoughts are!!
How can this be done right and safely
Load calcs for both the house and the pool are necessary. Unless it's a very larger load for the house, the boiler may not be sufficient for the pool.
Using a CI boiler to heat a pool is not a wise choice and will require boiler protection controls. It will also require the chimney to be properly lined and insulated. A mod/con would be less expensive and more efficient.Bob Boan
@SeanBeans I did a similar project up the hill from you with snow melt, radiant space heat and outdoor pools and hot tubs. We estimated the switch to mod/con would save them 20%. When we saw the actual year over savings it was ~32%.
Send me a PM if you want to a copy of the design."If you can't explain it simply, you don't understand it well enough"
Albert Einstein1 -
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 27 Recall Announcements
